Xeon E3 system build upgrade?
Discussion in 'Intel x86 CPUs and chipsets' started by Brad002, Mar 16, 2019 at 11:47 AM.
Keep or upgrade for the $
  1. Keep
    0 vote(s)
    0.0%
  2. Upgrade
    1 vote(s)
    100.0%
  1. Brad002
    Brad002 Member
    Dec 6, 2013
    3
    Currently I have the following build which I re-purposed from a Lenovo Thinkcentre E31 and placed into another case
    Xeon E3 1220 Sandy Bridge
    16GB RAM
    Nividia 1060 (from prev build)
    256GB SSD (from prev build)
    TT 450W PSU (from prev build)
    I have the opportunity to purchase the following build through an IT department for $300 AUD - it's a Lenovo P300
    Xeon E3 1241 V3 Haswell
    32GB RAM
    256GB SSD
    Optical Drive
    At the moment my current system does not have USB 3 - the newer one obviously would. I would likely place it into my existing case for the space
    I figure is the CPU jump worth it based on the cost?
    The PC is used for games at Med+ settings @ 1080P, general PC tasks etc
  2. demiurge3141
    demiurge3141 Member
    Aug 19, 2005
    1,347
    Melbourne 3073
    Depends on whether you are CPU limited in the games you play. You will see significant CPU performance gain as the e3-1220 lacks hyperthreading and is also clocked slower. However you could also just get an i7-2600 which should be less than $100. USB3 is moot since USB3 cards are a dime a dozen.
  3. wintermute000
    wintermute000 Member
    Jan 23, 2011
    1,704
    It would be worth it esp if you want all dat RAM. You get more threads and faster clocks and ~10-15% IPC. Don't forget you could sell your old CPU/RAM etc. and so the upgrade would not cost that much factoring that in.
    Brad002
    Brad002 Member
    Dec 6, 2013
    3
    What is the Xeon E3 1241 V3 Haswell "i" equivalent?
  5. wintermute000
    Jan 23, 2011
    1,704
    i7-4790 basically, give or take a hundred Mhz and a few W TDP. 4C/8T @ 3.6Ghz with turbo 4Ghz and 8M cache @ 84W TDP (vs 3.5-3.9 @ 80W).
    Brad002
    Brad002 Member
    Dec 6, 2013
    3
