XSPC Rasa 750 Water Cooling Kit
Discussion in 'Extreme and Water Cooling' started by Praneetn7, Jan 30, 2011.
  1. Praneetn7
    Praneetn7 Member
    Sep 20, 2010
    23
  2. Francis1
    Francis1 Member
    Dec 28, 2009
    124
    i was just looking at that lol. I was thinking the same thing, im tempted to try water cooling. and for 139 bucks why not?
  3. ChaosMaster
    ChaosMaster Member
    Jul 30, 2010
    1,302
    Vic, 3175
    It should be a pretty good kit. If you look closely, pccasegear has actually posted a link to a review for that product. 47 deg peak for a phenom is not bad. Do note that they did mention hat the pump was noisy during the first hour. Best thing you could do would be post a review here for us if you do purchase it.
  4. WuzzA21
    WuzzA21 Member
    Sep 29, 2009
    1,373
    That kit is a bargen, if you just want to even get rid of that CPU block and go wc your GPU.
  5. Francis1
    Francis1 Member
    Dec 28, 2009
    124
    hey guys how would this kit be ok with an antec 1200??
  6. Archy
    Archy New Member
    Jan 23, 2010
    1,312
    Glenhaven, Sydney
    Would it be up to a CPU and GPU loop?
  7. .Radiant
    .Radiant Member
    Nov 25, 2009
    4,837
    brizbun
    from what i can tell, no. need an extra radiator (or maybe go for the 360 ver?). been eyeing this for my antec 300, thinking of adding a 2x mcr220 stackable and a 120/140 rad in the future. still need to do a bit of research on the pump/res haha.
    edit: ah just saw that pccg don't offer the 360 ver.
  8. tunksy
    tunksy Member
    Dec 22, 2010
    380
    SA
  9. abc123asd
    abc123asd Member
    Jan 14, 2011
    339
    Melbourne, Victoria
    between pccasegear and gammods the price difference is alot. you could but the 240 kit at pccasegear and add a 360 rad for a couple of bucks more
    Praneetn7
    Praneetn7 Member
    Sep 20, 2010
    23
    Yes I did notice this and I was wondering if the pump could be okay with the triple rad
  11. .Radiant
    .Radiant Member
    Nov 25, 2009
    4,837
    brizbun
    the link that tunksy posted had the guy running a cpu block, tri-sli blocks and a 360 rad on the pump with some issue. so i'd imagine the 360 rad by itself would be fine.
  12. converge
    converge Member
    Aug 29, 2009
    2,316
    The rad is only an RS so don't expect amazing temps with an x58 setup (excluding 980x)
  13. abc123asd
    abc123asd Member
    Jan 14, 2011
    339
    Melbourne, Victoria
    does anyone know how to change the molex on the pump to a 3 pin fan header?
    i needa tutorial
    ps. sorry for kinda hijacking this thread
    Praneetn7
    Praneetn7 Member
    Sep 20, 2010
    23
    If I was to get this and get a triple rad or even another dual and run both rads together will I get better performance? At the moment I got the 920 running at 50 idle and 75 load which is very hot. :(
  15. tunksy
    tunksy Member
    Dec 22, 2010
    380
    SA
    yes on extremely hot days (like the last there here in SA) you will get better temps. plus on not so hot days, you will stay closer to ambient. win win. :thumbup:
    edit: oh yea, got an xspc x20 750 bay res/pump. Will put a little review up when I get my loop together later (sourcing a new cpu block and gpu cooling).
  16. Moarkill
    Moarkill Member
    Aug 30, 2010
    708
    what are the blocks usually like in kits like this? for that price i might grab one this week, just for cpu for now.
  17. tunksy
    tunksy Member
    Dec 22, 2010
    380
    SA
    mate, the xspc rasa block I had was top quality :thumbup: great price/performance, hence im getting another :lol:
  18. Moarkill
    Moarkill Member
    Aug 30, 2010
    708
    think im sold, might grab one tonight. Doesnt come with coolant tho right? Im new to Water, can i get usable coolant from bunnings or somewhere similar?
  19. tunksy
    tunksy Member
    Dec 22, 2010
    380
    SA
    use distilled water, you can get like 5L from woolworth or similar for bugger all. enjoy :thumbup:
  20. Moarkill
    Moarkill Member
    Aug 30, 2010
    708
    ok cool, and its good to use straight out of the bottle? Should i add anti-corrosive droips to it ?. Then i just need to get my fractal XL and i make a mod log
