Z390chipset, i9 9900k i79700k and i5
Discussion in 'Intel x86 CPUs and chipsets' started by kot0005, Jun 28, 2018.
  1. ausduckz
    ausduckz Member
    Oct 27, 2009
    223
    3691
    Bryan had his chip running pretty damn hot.
  2. shane41
    shane41 Member
    Nov 10, 2008
    6,978
    dice que no sabe
    End of the video. King of value, king of gaming, king of emptying your wallet & costing electricity :leet:
  3. OJR
    OJR Member
    Jan 19, 2013
    5,451
    Hardware canucks are not very technical. Their case reviews are good but everything else shows they have no idea.
  4. DSTM (Dougie)
    DSTM (Dougie) Member
    Jun 2, 2018
    676
    Western Sydney
    OK Thanks.:thumbup:
    Who do you follow for accurate information, on the net?
    Can't stand that Linus Tech guy.
  5. tek_01
    tek_01 Member
    Dec 4, 2005
    2,218
    SW Sydney
    maybe gamers nexus, jayztwocents, pauls hardware all seem ok
  6. DSTM (Dougie)
    Jun 2, 2018
    676
    Western Sydney
    Good one. Thanks.
  7. Plonkflopped
    Plonkflopped Member
    Feb 3, 2012
    491
    6700k > 9600k good enough jump to warrant the cost ? Looking for a new motherboard as mine is getting a little flaky so may as well do the CPU at the same time. Mainly used for gaming paired with a 1080ti.
  8. OJR
    OJR Member
    Jan 19, 2013
    5,451
    Gamers Nexus’s Steve is probably one of the most technical reviewers out there. AdoredTV is also very thorough although he doesn’t specifically review hardware that much. Level 1 Techs is also very good.
    Oh and der8auer
  9. WabbitHuntn
    WabbitHuntn Member
    Sep 1, 2006
    193
    Murray Bridge, SA
    Don't get angry at me for Intel's 115c rating
    I don't think anyone should push a CPU anywhere near that temp.
    I'd suggest you run no higher than 80c and that only for short periods of time.
    kot0005
    kot0005 Member
    Nov 11, 2011
    828
    melbourne
    are you insane ?? are you okay ? ? I am not running a cpu at 100c in a custom loop. I am definitely not.
    I would really like to know how many people on here running custom loop are okay with running their cpu at 80c+ on a custom loop. I am definitely not.
    I would also not buy a second hand cpu that was being run at such ridiculous temps. So it also decreases resale value.
    Cpu will also thermal throttle once u go above 80c.
    Something is definately up with this new stim. You shoundt be able to delid these with delidding tool.
  11. shane41
    shane41 Member
    Nov 10, 2008
    6,978
    dice que no sabe
    Don't even like 80deg in a 1x minute benchmark. Pushing the volts up ... I prefer cold ambient temp like wintertime 15deg & under.
    The solder is soft shit ... simple as that.
    Nope. I view anything in this 9 series other than the 9900K as down bins. HT disabled & defective cores turned off.
    Remember the 8350K could barely make 5Ghz. Rare a 8600K could make 5.3Ghz
    Best purchase is still the 8700K 8086K ... they rock :)
    DarkSnipa and adamsleath like this.
  12. macktheknife
    macktheknife Member
    Jul 26, 2005
    1,710
    Has anyone done thermals during game benchmarking?
  13. DarkSnipa
    DarkSnipa Member
    May 13, 2017
    853
    Nope, but interestingly under stress test my 9600K at stock will throttle to 4.3GHz all cores down from 4.6GHz all cores which never happened ever when I had a 8086K in my MSI Z370I motherboard, is it just me :confused:
    BTW guys I found Maximus XI Gene is listed on JD.com for 3100 cny (About 620 aud), I feel bad for those who want this board it is $100+ more than Maximus X Apex at launch.
    Edit: I just found a listing for Maximus Gene: http://ijk.com.au/branch/ijk/product_info.php?products_id=161728
  14. Radley
    Radley Member
    Feb 24, 2009
    2,561
    Coffs Harbour
    Why? Shear strength of solder is fuck all.
  15. PureFire
    PureFire Member
    Jun 25, 2002
    1,796
    Der8auer did a video on delidding and results
  16. AMD180
    AMD180 Member
    Dec 20, 2002
    217
    Geelong
    Just an update on this, have just picked up my 9900K from OC UK at the DHL Depot, ordered last Friday lunch time, picked up this morning. Not bad service at all!
    OC results to follow later tonight / tomorrow.
    shane41 likes this.
  17. tek_01
    tek_01 Member
    Dec 4, 2005
    2,218
    SW Sydney
    Good shit man keen to see some results even just at stock while Gaming lol, all these YouTube videos scaring the crap outta me
  18. Externalz
    Externalz Member
    Oct 26, 2007
    251
    Gotta agree with this, having serious second thoughts now.
  19. tek_01
    tek_01 Member
    Dec 4, 2005
    2,218
    SW Sydney
    By the off chance, has anyone purchased any z390 gigabyte boards here ? I want to compare something coz mine "might" be faulty
    even a z370 would probably work
    OJR likes this.
  20. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    158,339
    Omicron Persei 8
    Absolutely most annoying reviewer, ever. Period.
