Z390chipset, i9 9900k i79700k and i5
Discussion in 'Intel x86 CPUs and chipsets' started by kot0005, Jun 28, 2018.
  1. Partha
    Partha Member
    Mar 17, 2009
    1,277
    You have updated the Mobo BIOS right ? I remember some youtuber had a hell of a time trying to get 9900Ks to work properly only to find at the very end that he needed to update the Mobo BIOS. Here is that link although his problem was different
    Are you also saying that the 9900K on the same motherboard with same setting can fly higher then 127W but with the same settings on same motherboard, the 9900KS is restricted to TDP ?
    This video from Gamers Nexusshows how different motherboard vendors is handling the EPS powers differently. May be you need to change your Mobo to Gigabyte ? May be MSI is following restrictions like ASUS.
    You may need to reach out to MSI suppport via Facebook etc. I have reached out to them before and they are usually quite responsive.
  2. shane41
    shane41 Member
    Nov 10, 2008
    6,293
    dice que no sabe
    Yeah could be bios. I'm on Apex with latest bios, I'm not sure if it handles the processor different. As I always ran earlier 1801 with 8086K
  3. jekel
    jekel Member
    Jul 24, 2004
    402
    Hi guys just wondering your thoughts on cheap z390 motherboards vs high end for 9900k?
    I'm using low end Asus Tuf Z390 gaming matx as wanted smaller board/case. Seems to run perfect and testing 5ghz all core 1.3volts seemed stable with temps hitting max 70degrees.
    Many comments online saying 9900k needs better vrm boards but I dont feel like my current board is causing any issues and I'm not aiming for biggest overclock that is possible. Would you bother getting a better motherboard?
  4. shane41
    shane41 Member
    Nov 10, 2008
    6,293
    dice que no sabe
    Ran 9900KS on MSI itx board. OC on 52-53x 1.4Vcore. Fan over the vrm section. That's an average $300 board new
  5. jekel
    jekel Member
    Jul 24, 2004
    402
    Thanks, think no need to upgrade lol....need to stop reading the vrm articles which make me want to upgrade.....since I'm not aiming big overclock anyway.
  6. shane41
    shane41 Member
    Nov 10, 2008
    6,293
    dice que no sabe
    Just keep your shit running cool. An easy OC now is 5Ghz 1.3v
  7. chainbolt
    chainbolt Member
    106,602
    Tokyo
    1.4? That is with what cooling?
  8. im late
    im late Member
    Jan 5, 2012
    1,631
    Canning Vale WA 6155
    Cooling is likely this
  9. chainbolt
    chainbolt Member
    106,602
    Tokyo
    Good Lord, that looks really serious. Explains the 1.4 volt. :thumbup:
    For what it matters, I have my 9700K running (stable enough for gaming) at 5 GHz at 1.3 volt with AIO cooling. After an hour or so running Prime 95, one of the cores gives up. My AIO cannot handle temperatures above 1.3 volt.
  10. shane41
    shane41 Member
    Nov 10, 2008
    6,293
    dice que no sabe
    Not serious enough though it seems. :tongue: Sometime in the future I'll turn Apprentice HWbot & make my " as Splave said :tongue: " scores look alright!
