1. We're giving away an NVIDIA RTX 6000 video card!
  2. OCAU Merchandise is available! Check out our 20th Anniversary Mugs, Classic Logo Shirts and much more! Discussion in this thread.
  3. We're giving away an NVIDIA RTX 6000 video card!
  4. OCAU Merchandise is available! Check out our 20th Anniversary Mugs, Classic Logo Shirts and much more! Discussion in this thread.
Intel cpu flaw - kernel memory leaking
Discussion in 'Intel x86 CPUs and chipsets' started by argent, Jan 3, 2018.
  1. dirtyd
    dirtyd Member
    Jan 4, 2006
    4,262
    Melbs
  2. cvidler
    cvidler Member
    19,821
    unless you're the CIA wanting to target Iranian reactors, malware is very rarely targeted at anything other than 'everything and anything'.
  3. ipv6ready
    ipv6ready Member
    Feb 10, 2014
    3,606
    North Sydney
    So I presume it is Kabylake and down that is affected by the bug.
  4. mAJORD
    mAJORD Member
    Jun 4, 2002
    14,298
    Griffin , Brisbane
    AMD has only confirmed 1 of the 3 exploits announced require a workaround - It's that simple.
  5. genxor
    genxor Member
    May 9, 2003
    487
    Anything made in the last 10 years apparently so that'd be a shitload of CPUs if true. Pretty scary that the majority won't be patched
  6. Pemalite
    Pemalite Member
    Jul 20, 2010
    723
    Port Lincoln, SA
    I am just laughing at you being in damage control.
    This is just Karma after all your immature Failzen bashing.
    Intel gone and stuffed up massively. Accept it and move on, these things happen, in-fact it is not the first time a massive flaw has been found in Intel processors. (Or AMD for that matter.)
    And it will happen again.
    As processors grow exponentially in size... Then so does their chances of errata.
    VirtualNinja likes this.
  7. flu!d
    flu!d Motoring and Intel forum admin
    23,489
    There's two exploits here, one of which affects every processor out there with the exception of Cirtix and Via (sarcasm intended).
    Doesn't bother me as I'm not the kind of person that wastes money on a constant upgrade cycle in order to have the best sig, I'm still running an x58 system with a Xeon in my main rig under Linux and a 2700k in my Windows PC, which I never use as Windows 10 sucks - Both have served me exceptionally well. When the time comes that this issue is resolved in silicon, I'll update my rig (probably get rid of the Windows rig) and be happy for the next ten years.
  8. Apokalipse
    Apokalipse Member
    May 29, 2006
    4,250
    Only variant 1, on Linux in a non-default configuration (when you have explicitly enabled eBPF JIT). Not on Windows at all.
    AMD is not vulnerable to variant 2 or variant 3.
  9. Zenskas
    Zenskas Member
    Jan 27, 2010
    2,161
    Tas
    Linus has made a comment here (no not that Linus, the smart one)
    I really hope this doesn't affect general desktop performance more than a few percent...most of my PCs are running Intel chips :(
    In gaming I've read that the fixes don't have any initial negative impacts but I think way more testing will need to be done before I believe that. Minimum frames and frame pacing being the two areas that need a really close look IMO.
  10. GumbyNoTalent
    GumbyNoTalent Member
    Jan 8, 2003
    11,892
    Briz Vegas
  11. itsmydamnation
    itsmydamnation Member
    Apr 30, 2003
    10,742
    There are three attack vectors grouped into 2 pretty/cute names. all 3 effect Intel, arm has acknowledged that all three can be an issue for them. AMD has stated that meltdown doesn't effect them, that they believe they are secure to one of spectre attacks and acknowledge vulnerability to one.
    If you read the spectre paper they never were able to get both attacks on amd to work but believe it is vulnerable. AMD on the otherhand believe that they arent vulnerable to the second method of attack. So right now it's 3 of 3 for Intel and 3 of 3 for arm and 1 of 3 for amd.
    anyone who says differently should stop spreading FUD and put there money where there mouth is and produce evidence of the compromise!
    VirtualNinja and AEKaBeer like this.
  12. flu!d
    23,489
    With the exception of Intel, until there are no 'can', believe' and 'never were ables' - It's all FUD.
  13. itsmydamnation
    Apr 30, 2003
    10,742
    Bull**** , systems are complex and new discoveries are made and things change over time. Researchers have been working on the for 1/2 a year as it stands its 1 of 3 for AMD, to say anything else at the stage is simply incorrect.
    There is very strong language around meltdown, and less strong words around Branch Target Injection. Thats because speculative execution is extremely complex crossing many domains within the CPU ( predict, prefetch, decode/op cache, Load and store, Retirement) so that increases the risk of a possible attack vector(swiss cheese model) compared to the much simpler to protect against in hardware Rogue Data Cache Load ( Meltdown).
    Again this is all false equivalence, if AMD are vulnerable to Branch Target Injection researchers haven't been able to find it and/or make it work in 6 months but have empirical data of successful compromise for other vendors.
    mAJORD likes this.
  14. BiggusDickus
    BiggusDickus Member
    Aug 8, 2006
    341
    Brentwood WA
  15. adamsleath
    adamsleath Member
    Oct 17, 2006
    24,385
    Sunnybank Q 4109
    need to see revised benchmarks after the patching.
  16. Supersize
    Supersize Member
    Jul 30, 2008
    2,576
    Gold Coast QLD
  17. General_Cartman
    General_Cartman Member
    Apr 28, 2005
    2,752
    The Confedaracah!
    Unless you're doing a lot of IO you won't see that much of a performance decrease. Home users don't really have anything to worry about. Database servers - that's a completely different story.
  18. BiggusDickus
    BiggusDickus Member
    Aug 8, 2006
    341
    Brentwood WA
    Would multiplayer gaming count as a lot of IO? I'm not sure how this would compare to web server levels of IO...
  19. pH@tTm@N
    pH@tTm@N Member
    2,590
    BRISBANE
    hypervisors will be hit heavily. if you only have 30% overhead capacity remaining kiss it goodbye.
  20. im late
    im late Member
    Jan 5, 2012
    1,899
    Booragoon WA 6154
